Humble Thanks
Old 10-17-2018, 02:47 PM
The Deputy's Avatar
Received 1,160 Likes on 836 Posts
Was your air ride converted to coil?
Also, you can help isolate the problem by disconnecting the negative terminal from the battery and connecting a test light in between (one end hooked to negative post and other to the metal portion of the body). If test light...lights up...you have a drain. Start pulling fuses until it goes out. *Best to roll down driver's window, close doors (so dome lights go out completely) and wait a few minutes for the vehicles electronics to "go to sleep". Because, these could keep the test light lit for a short period of time...giving you a false reading at first.
If it doesn't go out by pulling fuses, then you will have to disconnect alternator, or starter, or any other add-on electrical items you may have.
​​​​​​​ Brian.
Old 10-17-2018, 03:01 PM
The Deputy's Avatar
Also, you should always remove negative terminal from battery first, when disconnecting. You can cause an arc while removing positive, causing the battery to explode (especially, if the battery has been being charged from a dead condition). Plus, some electronics (ECM, BCM, etc) do not like the power surge that comes along with the arcing of positive cable removal or installation. Always remove negative first and install it last.
​​​​​​​ Brian.
Old 10-18-2018, 06:26 AM
oaty's Avatar
Thanks. No Air Coil Conversion. I have a 2000 SD D2. ITs difficult for me because I am not an electrician. I will remove the Neg, I have looked at the battery drain post and what to do, just not that far yet. Thanks for the heads up. I would like to install a disconnect switch, not sure which is best with the Land rover battery connectors being different. Which disconnect works best with the D2 Pos Battery connector?
Old 10-18-2018, 07:45 AM
abran's Avatar
Originally Posted by oaty
My Pos battery clamp will not tighten anymore..
Tske a 3” long piece of 10 or 12 gauge wire, strip back half of it, when placing clamp on post put the stripped section in between post and clamp.
this Land Rover will turn you into a mechanic real quick!
Old 10-18-2018, 08:56 AM
oaty's Avatar
Thanks Abran, you are the MAN!
oaty
10-11-2018 08:53 AM
oaty
11-03-2017 08:11 AM
filthydisco01
08-02-2015 09:19 PM
Grant7109
03-22-2014 07:03 PM
hillbilly
Other
10-16-2008 08:46 PM
Quick Reply: Humble Thanks
