HVAC always on
Old May 11, 2013 | 12:14 AM
toofaroffroad's Avatar
Default HVAC always on
This is not a big issue and it's something I can easily live with but I figured i'd throw it out there in case there is an easy fix.
My heater/AC is always on. Basically when you turn the vent system off it will continue to blow air It blows whatever setting the system was on when it was turned off. It only seems to blow heavy when on the hwy, when driving around town it blows but very little.
Any ideas.
Old May 11, 2013 | 03:56 AM
jfall's Avatar
Sounds like your driver transistor is shorted closed.
Probably an open collector PNP type.
Old May 11, 2013 | 07:48 AM
poncePR's Avatar
My 02 has the same problem but I never bother to look into it.I figure if a disco is not overheating and its liners are staying put....its running perfect!
Old May 11, 2013 | 10:57 AM
So, are you saying the fans never turn off or do you still get air flow when off that might vary based on your vehicles speed?
Old May 11, 2013 | 05:42 PM
poncePR's Avatar
Don't know about op but when My fans are off I still get air flow with vehicle speed.
Old May 11, 2013 | 11:57 PM
Rover_Hokie's Avatar
X2, volume dependent on speed, and temp dependent on outdoor temp.
Old May 12, 2013 | 07:55 AM
If you pull fuse 7 under dash that should stop main HVAC fan. Then you can decide if you have a fried relay or power transistor module.
Old May 12, 2013 | 12:40 PM
Default fan
D Mike, it blows depending on the speed of my truck. On hwy it's blowing pretty strong when vent is off, when in city it's minimal. Is there a way to set the vent so it's just blowing air from outside instead of always setting temp involving heat and AC? I could live with that.
ScottinNJ
Jul 9, 2007 08:19 AM
dcarsmith
Mar 8, 2007 10:16 PM
nuno106
Oct 30, 2006 03:31 PM
alpinab7
Sep 29, 2006 03:11 AM
jons1998RRHSE
Sep 11, 2006 03:50 PM
