I have a long block...now what?
Old Aug 11, 2020 | 08:58 PM
greisinb's Avatar
Default I have a long block...now what?
Ok, so a D2 popped up in my local wrecking yard, after grabbing the bits I needed (no bumper, bummer) I decided that I apparently had more time then sense and decided to pull the block. Many hours later it sits in my garage. Now what?
My current plan is to tear it down and rebuild it as time and budget allows. My current motor is OK (but at 175k) so I’m not in a huge time crunch. The one I pulled has SAI and my current motor doesn’t, can I just plug the SAI holes?
Old Aug 12, 2020 | 05:31 PM
Extinct's Avatar
Get it apart while there is still whatever warranty in place that it came with. Sometimes the cylinders are wiped out.
Old Aug 12, 2020 | 06:04 PM
greisinb's Avatar
No warranty, but head removal is going to be the first thing when I get around to it to check for signs of a slipped sleeve.
Old Aug 12, 2020 | 06:53 PM
The_OGCJR's Avatar
Yes you can plug it
id strip it down, get heads and block checked at machine shop
have block top hatted
have upper and lower im ported and matched
depending on cost have heads ported too
rebuild with new seals of course
new oil pump
new water pump
new high performance cam
New valves
new lifters
new springs
new rocker arms unless there’s absolutely no damage
that’s if you want to kill 2 birds with one stone and make sure the engine has more power and lasts forever...
but if you want something cheap then just have heads and block checked and rebuild with new seals. I’d still say new springs, lifters and oil pump though
Scarf
Jul 9, 2018 06:56 PM
zuke
Apr 23, 2018 09:33 PM
dcdiscovery
Oct 23, 2017 10:03 AM
d.a.r.y.l
Jul 27, 2016 09:37 AM
knightmetro
Dec 4, 2014 09:06 AM
