I killed my power steering pump (I think)
Old Jun 19, 2018 | 03:19 PM
shanechevelle's Avatar
Originally Posted by Roby466
alright I see, I will take it apart again and see what it does. It's a pretty quick job. The worst is the fluid. That LR steering fluid is getting expensive Not sure if any PS fluid can go in there can it? I know D1 used auto trans fluid. D2 is supposed to have PAS fluid.
I use any ps fluid
Old Jun 22, 2018 | 07:23 AM
Roby466's Avatar
Ok, I’ll pull the pump this weekend and try that. I suppose you have to make a semi-thick bead if you don’t torque the back cover that much? Not 1/8in but not a smear either.
Old Jun 23, 2018 | 07:44 PM
No...I just use a smear. I smear both sides of the gasket...but, I also make sure I run my finger on the inside part if the pump where the gasket sits, it helps seal...but not too much just a thin skin.
Try this...
When you're tightening the bolts on the back, spin the pulley and as you tighten you'll feel how the pump gets harder to turn.
What I do is tighten the bolts just tight enough to create a drag.
Old Jun 24, 2018 | 06:49 AM
Roby466's Avatar
Well it didn’t work. If I don’t want the drag it doesn’t seal (at all). I inspected and when it ran dry at first it wore some grooves in the plate. You can see from the picture. I suppose that makes the extra drag and too much leak by. These pictures are after I polished the plate a bit.
I ordered a rebuilt one by A1 Cardone.
Cheers
David
kudu500
Dec 10, 2013 04:25 AM
jrb
LR4
Dec 7, 2011 06:43 PM
will2k
May 29, 2008 03:55 PM
DeepBlueWater
Dec 8, 2007 10:55 PM
