Smoke and leaking.
Old Jun 22, 2018 | 12:44 PM
Phlegyas's Avatar
4th Gear
Default Smoke and leaking.
I've got a 2000 Discovery II it's been leaking on the carpet of the passenger side floor, and can occasionally hear water swishing around from the passenger side. Sounds like it's coming from behind the glove box. Today I noticed smoke coming from the air vents. What could be causing this?
Old Jun 22, 2018 | 01:24 PM
jamestfl's Avatar
The water sloshing sounds like air in the cooling system- fill with coolant and burp as needed. Smoke might not be so good. Got a fire extinguisher?
Old Jun 22, 2018 | 01:59 PM
Red5's Avatar
I'm guessing a failing heater core. I once had a core fail (not the LR but they're all the same) and along with the wet carpet, I had lots of "smoke like" water vapor coming out of the vents.
Do you smell antifreeze?
Old Jun 22, 2018 | 02:04 PM
Phlegyas's Avatar
4th Gear
I do have a fire extinguisher, hopefully it doesn't come to that. Could the heater core also affect my AC?
Old Jun 23, 2018 | 08:18 AM
Red5's Avatar
What trouble do you have with the AC?
Old Jun 23, 2018 | 08:33 AM
razorkill12's Avatar
sounds like heater core leaking....
Old Jun 23, 2018 | 10:44 AM
Phlegyas's Avatar
4th Gear
It just hasn't been working at all. Even on full blast I can only feel it a little bit while the vehicle is actually moving. How would I go about fixing a leaking heater core?
Old Jun 23, 2018 | 07:52 PM
shanechevelle's Avatar
First you need to determine if its coolant or rain water from the sunroof.
The sloshing is air, you need to bleed it until you get rid of that noise.
A heater core problem, you need to swap it out by removing it. Download the rave for the details.
Old Jun 24, 2018 | 06:57 PM
Twix's Avatar
Replacing the heater core on these is a horrible job. You gotta remove the entire dash assembly. But if the carpet is wet, look up under the passenger kick panel, you'll be able to see the drip. The AC could be a different issue all together, but I suspect there's a leak in that system due to the heater core cracking.
TheresNoSuchThingAsDryLandRover
Aug 11, 2018 05:35 PM
JasonjCook
Jun 18, 2013 11:09 AM
racer11x
Freelander
Dec 24, 2008 09:42 AM
monkey2727
Feb 16, 2008 11:02 AM
nfosterweb
Feb 22, 2006 11:32 AM
