IACV to intake connection
Old Feb 28, 2019 | 01:20 AM
Gonow's Avatar
Default IACV to intake connection
I got a P1551 and P1514 so I checked all the IACV connections. I noticed the connection to the intake was quite loose and easily disconnected. Is it supposed to look like this? Shouldn’t the metallic coupling be somehow attached to the intake so the vacuum hose can then be secured to it?
Old Feb 28, 2019 | 02:33 AM
JUKE179r's Avatar
That's no bueno muchacho.
Old Feb 28, 2019 | 07:36 AM
Best4x4's Avatar
I’d remove the metal pipe from the rubber hose & using a rubber mallet see if you can get it to go back into place. If not you may have to drill a small hole from the top & add a set screw to hold it into place or find another upper intake manifold.
Old Feb 28, 2019 | 09:11 AM
Red5's Avatar
Mine did that once. The rubber mallet trick that Best suggested worked fine for me.
Old Feb 28, 2019 | 09:25 AM
Gonow's Avatar
Thanks. I’ll give that a try.
Old Feb 28, 2019 | 09:38 AM
User's Avatar
This is a perfect opportunity to install a supercharger and bypass that brass piece at all.
Old Feb 28, 2019 | 10:08 AM
CollieRover's Avatar
JB Weld it back in place? The pipe for my purge valve came out and that has worked like a charm.
Old Feb 28, 2019 | 01:51 PM
Gonow's Avatar
I tried Best4x4’s idea and it worked. I did spray a bit of high-tack on the 1/2 of the brass fitting that goes into the intake. The other half I put a light coat of Vasoline to help the vacuum hose slip on/off. So far so good!
discorona
Feb 21, 2019 10:00 AM
rcrosby
Oct 2, 2018 05:47 PM
chubbs878
Dec 24, 2015 08:44 AM
bearcatfans
Jun 21, 2013 09:56 AM
buick215
Nov 11, 2012 08:05 PM
