idiots quest for more power?
Old Nov 6, 2014 | 09:16 PM
  #131
dusty1's Avatar
that's just it. I have a well taken care of 4.0 in it. not 4.6, but I figure......may as well get the biggest gain possible while I am putting the 4.6 together. fun! not trying to build anything that is likely to fail or cause a ton of problems. i'd go for a sbc swap if I wanted to deal with headaches of computers and adapting.
I am going to keep the perfectly running 4.0 as a spare or maybe stick it in another truck
Old Nov 6, 2014 | 09:27 PM
  #132
dusty1's Avatar
and I do not plan of the nos. I was mostly interested in learning the capabilities.
but since you brought it up ..... is there a better injector choice? not really seeing any advantages with different.
Old Nov 7, 2014 | 07:04 AM
  #133
Alex_M's Avatar
When I did all my work I looked at injectors. The closest thing I found to fitting was ford mustang 19lb injectors that a lot of guys seem to have put in their Range Rovers and Disco 1s. I ordered a set without making sure they would fit the D2, only to learn they were longer than the D2 injectors. Upon closer inspection, stock injectors are also 19 lb with a 4 hole design.
In short, I have not found any injectors that would work as an upgrade, nor have I found anyone on the Web who has ever upgraded the injectors in their D2.
Old Nov 7, 2014 | 07:09 AM
  #134
dusty1's Avatar
Yeah, same here. found no real advantages to swap to other injectors. d1 appears to like ford ones. notta for us
Old Nov 9, 2014 | 12:34 AM
  #135
dusty1's Avatar
So..... I am thinking , stick to the shaft on rockers. Easy enough to go stud or shaft.....couple of bucks difference.
My thinking= I don't want a hollows oiling, I'd rather have solid hd. Am I missing something? If I have adjustable rollers on standard rover shaft, am I missing some benefit of stud mounting the arms? Small difference is 10mm spacers for covers if I go shaft. $75 for spacers.
Also I found Buick 300 rocker arms with the same numbers, but cheaper.
Old Dec 1, 2014 | 07:43 AM
  #136
dusty1's Avatar
ordering bearings and rings and have a question.
are the con rod bolts sty? me thinks yes, as I have found an arp set that says "torque pre stretch instructions" but those are for 3.5/3.9/4.2....so older. I think there is a difference, but not 100% sure. still I think they are sty, but I would like a second on that. just want to know if I needs em.
Old Dec 1, 2014 | 08:00 AM
  #137
drowssap's Avatar
stock rod bolts are sty bolts. i have seen arp rod bolts. are you looking at their site or someone elses sight
Old Dec 1, 2014 | 08:12 AM
  #138
dusty1's Avatar
v8tuner.....I will go to their site
Old Dec 1, 2014 | 08:16 AM
  #139
dusty1's Avatar
arp has a main set, a couple of head sets, and a flywheel set
Old Dec 1, 2014 | 08:40 AM
  #140
drowssap's Avatar
try here or here
Buick 215 Rover 3.5 Land Rover 4.0 and 4.6 differences
West Coast British
