idiots quest for more power?
that's just it. I have a well taken care of 4.0 in it. not 4.6, but I figure......may as well get the biggest gain possible while I am putting the 4.6 together. fun! not trying to build anything that is likely to fail or cause a ton of problems. i'd go for a sbc swap if I wanted to deal with headaches of computers and adapting.
I am going to keep the perfectly running 4.0 as a spare or maybe stick it in another truck
and I do not plan of the nos. I was mostly interested in learning the capabilities.
but since you brought it up ..... is there a better injector choice? not really seeing any advantages with different.
In short, I have not found any injectors that would work as an upgrade, nor have I found anyone on the Web who has ever upgraded the injectors in their D2.
So..... I am thinking , stick to the shaft on rockers. Easy enough to go stud or shaft.....couple of bucks difference.
My thinking= I don't want a hollows oiling, I'd rather have solid hd. Am I missing something? If I have adjustable rollers on standard rover shaft, am I missing some benefit of stud mounting the arms? Small difference is 10mm spacers for covers if I go shaft. $75 for spacers.
Also I found Buick 300 rocker arms with the same numbers, but cheaper.
ordering bearings and rings and have a question.
are the con rod bolts sty? me thinks yes, as I have found an arp set that says "torque pre stretch instructions" but those are for 3.5/3.9/4.2....so older. I think there is a difference, but not 100% sure. still I think they are sty, but I would like a second on that. just want to know if I needs em.
