Idle control motor vibrating with key off
Old Jun 26, 2013 | 11:46 PM
jfall's Avatar
Default Idle control motor vibrating with key off
All,
I open my hood in the garage to let out the hot air when I pull in after work.
Heard a buzzing noise.
Put my hand on the idle air control motor..
Was vibrating with the engine off.
Key off.
This seems like a problem which will eventually ruin the idle control motor mechanism.
Old Jun 27, 2013 | 12:29 AM
Pull fuse 1 in underhood box. That runs a lot of engine management including injectors and the IACV. If pulling that kills the "buzz" maybe the main relay is fried.
Old Jun 27, 2013 | 11:40 AM
clanch's Avatar
Also can be worn ignition switch
Old Jun 27, 2013 | 08:47 PM
BCDisco2Lando's Avatar
This is interesting as we are running into the same issue with the IACV. The other thing we noticed is the fuse block under the hood has a clicking noise from one of the relays and we tracked it down to the ABS relay and pulled that relay and no more clicking. When we pulled the relay for the ABS we heard an under lying sound that sounds like a faint buzzing soundcoming from the fuse block. coulkd this be realted to the IACV making its buzzing sound?
Old Jun 28, 2013 | 01:21 AM
jfall's Avatar
Probably.
I do appreciate the feedback.
Great detective work.
All I know - is
'systems still on'
with key off - are trouble.
Either will drain the batter and / or will destroy the part in question.
I need to do more troubleshooting.
zeblitz
Aug 24, 2014 08:33 AM
schwaggy
Apr 8, 2014 07:52 PM
Suede
Apr 28, 2010 10:07 PM
SherryG
Oct 16, 2007 07:51 AM
samsly
Jan 4, 2006 04:37 PM
