If you have the clunck when you get back on the gas, I found the culprit
Old Apr 21, 2018 | 06:03 PM
Frank4's Avatar
Default If you have the clunck when you get back on the gas, I found the culprit
On the top of the rear ACE piston there is a bushing where is connects to a bracket. I can now say that it’s the source of my clunk.
Old Apr 21, 2018 | 09:02 PM
naivedisco2's Avatar
I have a clunk when I let off the gas, and I finally decided it’s almost definitely the front output of the transfer case. Lots of slop, and when I bought the rover there was a size difference of whole inches between the set of front tires and rear tires. Guess it looked better that way on the 20” RR wheels they had on it... 🙄
Old Apr 21, 2018 | 10:11 PM
Frank4's Avatar
Could be, but climb under the rear and take a look at the bushing in blue.
Attached Thumbnails If you have the clunck when you get back on the gas, I found the culprit-41130d51-8076-439e-8daa-15229a4e748e.png
tre soli
Jan 1, 2014 12:40 AM
mx468
Aug 3, 2012 05:38 PM
bosshogt
Dec 23, 2011 10:24 AM
