Infamous Knocking Slipped Sleeve DII
Old Dec 5, 2012 | 10:58 AM
grandkodiak's Avatar
Did you try pulling a plug wire at a time to really rule out ignition knock for each cylinder?
Old Dec 5, 2012 | 11:13 AM
jfall's Avatar
Sleeve knocks after the engine is really warm. Say after 10 minutes and driving a few miles.
If you have a knock upon start up - say in the first 30 seconds - it MAY NOT be a sleeve.
Could be lower end - rod bearing.
Before you spin a bearing, you can get the bearing shells for about $300 and put them in yourself.
IF you have a sleeve knocking at engine startup - that seems rare.
If it is 40 to 30 degrees out and you first start up and have a knock, probably NOT a sleeve.
jfall's Avatar
Sleeve is more a metallic tick. Like a super loud valve tick.
I heard one in person when I test drove a rover with a sleeve issue.
Old Dec 5, 2012 | 03:34 PM
Dan7's Avatar
Sleeves sound like a diesel motor, only they appear after the engine's warmed up vice go away like in a diesel. Perhaps an exhaust leak...would account for the noise and maybe the smell. Got an audio clip you can post?
rudawski
Apr 18, 2023 07:17 AM
primussucks
Dec 4, 2012 12:28 PM
ltbrkm3
May 15, 2012 10:27 AM
molendast
Oct 13, 2011 09:19 AM
CurlyE
Mar 10, 2011 09:10 PM
