Inline thermostat fail!!!
Old Jul 24, 2017 | 11:07 PM
  #41
Luckyjayb's Avatar
Originally Posted by Alex_M
Right, but there weren't massive gaps around the factory tee.
Notice the holes. This was my shroud
Old Jul 24, 2017 | 11:31 PM
  #42
Alex_M's Avatar
Right, I understand that, but the hoses in the factory orientation mostly block them.
Old Jul 24, 2017 | 11:35 PM
  #43
Luckyjayb's Avatar
i get what you are saying. They are mainly still blocking but I just ordered a replacement and probally going back with the 180 genuine or I'll swap the locations back around so no cutting needed
Old Jul 25, 2017 | 12:37 AM
  #44
huggi's Avatar
I live in North Jersey just outside NYC
Originally Posted by Best4x4
Where are you from Huggi?
Old Jul 25, 2017 | 06:40 AM
  #45
dgi 07's Avatar
Originally Posted by huggi
My inline mod maxes out around 194, in 100* weather. Usually runs in 183-188 range in normal weather.
Those are my numbers as well.
This morning was 63 degrees ambient, didn't seen anything over 183, and that was after sitting at a light for a few minutes.
Last week when it was 95-102 ambient, I saw nothing but 188-194. Highway speeds didn't help and my thermostat is in the same place as your first picture. I run no bleeder.
Old Jul 25, 2017 | 08:09 AM
  #46
Externet's Avatar
Originally Posted by Luckyjayb
what did you use if I make ask. Looks good if you have part numbers that would be great
05May2015.-Plastic filler neck Dorman part number 902-305, $14 at Walmart.com; force inserted into hoses as it is meant to be used for 1 3/4" hoses. There is other suitable types, as part PRW 5292272. Some shroud plastic shaving underneath needed to nest the contraption lower for hood clearance. $2 Ninety degree in-line thermostat housing from a random boneyard find with no bypass hose. $6 thermostat is a 180 degree generic from AutoZone store.
Old Jul 25, 2017 | 10:46 AM
  #47
Alex_M's Avatar
That should make a difference. Looking at your pictures there looks like there's already several square inches of gap. That's a lot more airflow being diverted than it seems in relation to the air flow coming through the radiator. A radiator has, roughly guessing, 25% open area. That means even if it's 24"x18" (another rough estimate; can't remember exactly) making an area of 432 sq inches, then that's an open area of 108 sq inches, roughly. Looking at your pictures I'd guess you have 6-8 sq in of open space cut out. That's almost 6-8% of air flow not being pulled through the radiator and therefore not cooling anything.
There are of course other factors that come into play, but that is a good rough estimate.
Do you remember what you got the thermostat housings off of? I don't have any pick and pull yards around.
Old Jul 25, 2017 | 11:40 AM
  #48
Luckyjayb's Avatar
Do you remember what you got the thermostat housings off of? I don't have any pick and pull yards around.[/QUOTE]
I wanna know the same. That looks a lot easier
Old Jul 25, 2017 | 07:10 PM
  #49
Externet's Avatar
Sorry, fellows. The engine I pulled the 90 degree thermostat housing out of was out of the vehicle, there were rows of engines on shelves and lined on the floor. A walk trough them easily spotted it. Vaguely remember either a Pontiac, Nissan... 4 cylinder, front wheel drive about 15+ years old plain Jane. Had a longer neck than needed, hacked it shorter. Drilled two 3mm holes to the thermostat, barely visible in the picture.
An auto parts store with a friendly clerk should be able to pick one from their pictorial catalogs.
Or check among hundreds at
----> http://www.dormanproducts.com/gsearc...tart=50&num=25
Or go to the store with a print of the following actual photo :
From the web :
----> https://www.mustangsunlimited.com/pr...g+Cougar_S.jpg
----> http://cdn.shopify.com/s/files/1/006...g?v=1296226689
Mine :
velija
Apr 6, 2019 11:46 PM
03discoman
Nov 18, 2016 02:01 PM
A5scott
Jul 28, 2012 11:01 PM
DiscoRover007
Jul 16, 2012 08:58 AM
ATLDisco
Apr 4, 2012 07:00 AM
