oil pump tool?
Old Jul 25, 2017 | 02:17 PM
Sixpack577's Avatar
Default oil pump tool?
I was reading the service manual, as I'll be replacing several parts in the engine at the weekend.
The manual shows a special tool for reassembling the front cover.
It appears that tool is used to line up the outer oil pump gear with the crank gear.
Is there any way to assemble the cover without the specialty tool? Or any other more common tool that can be substituted?
I was hoping to leave the radiator in too, but it looks like I'll need room for an impact wrench to break loose the crankshaft pulley nut. Torque spec says 200 ft lbs.
Are there any tricks for replacing the oil pump?
I'm replacing the front driveshaft as well, so that will make dropping the oil pan easy.
Thanks for any advice.
Old Jul 25, 2017 | 02:29 PM
KingKoopa's Avatar
Crankshaft bolt can be loosened with a long breaker bar against the frame rail, and bumping the starter.
Old Jul 25, 2017 | 03:06 PM
Alex_M's Avatar
I just took it in and out, rotating the pump a little by hand until I got the alignment close enough to go on. No special tool necessary.
Old Jul 25, 2017 | 03:07 PM
Alex_M's Avatar
https://landroverforums.com/forum/di...38/#post548912
Here's all the information you could ever want about the job. This is a full step by step I did with pictures.
Old Jul 25, 2017 | 03:26 PM
Sixpack577's Avatar
Oh, now that's just cheatin, lol.
...and a great idea!
Old Jul 25, 2017 | 03:27 PM
Sixpack577's Avatar
I was really hoping that was possible.
Thank you
Sixpack577's Avatar
Excellent!
Thank you sir!
Old Jul 25, 2017 | 03:43 PM
abran's Avatar
Another way, since the pan has to come off, wedge a 2x4 in between a crank lobe and block and undo the crank bolt. Also the way to get it torqued back on.
Old Jul 25, 2017 | 07:26 PM
Sixpack577's Avatar
Also an excellent idea!
I was wondering how/where to hold to torque it.
Thank you!
Oasisplayer311
Aug 12, 2015 10:43 PM
pilsner
Jun 18, 2012 05:05 PM
DiscoBenjamin
Jun 13, 2011 02:20 PM
pcrightler
Aug 25, 2008 07:52 PM
barranr
Jun 3, 2007 06:36 AM
