Installed KC lights, now battery dead
Old Apr 16, 2025 | 04:10 PM
rikkd's Avatar
Let us know what you come up with!
Old Apr 17, 2025 | 07:25 PM
fowlerjk04's Avatar
Replaced the alternator. Jumped battery. Starts, but alternator appears to be generating only 0.5v.
Old Apr 18, 2025 | 12:37 PM
Richard Gallant's Avatar
@fowlerjk04 You need to test alternator output at 3 places, but 1st verify you belt routing is correct according to the Rave and your belt is tight
  • Alternator positive to alternator casing 14+ volts
  • Alternator positive to primary ground on the engine block 14+ Volts
  • Alternator positive to battery ground if you can it is a bit of a reach 13.8 + there is some drop with all the ground connections in between
Old Apr 18, 2025 | 09:49 PM
CharminULTRA's Avatar
Very possibly another bad alternator. I went through 2 new alternators before finding a 3rd that actually worked. You also must install it with the battery unplugged otherwise you can fry the electronics inside.
Old Apr 19, 2025 | 08:46 AM
H20nSnow's Avatar
Do you have the new lights all disconnected? Have you undone (or at least isolated) all of the new connections you made to support the new lights? You said that your problem seemed to appear when the new lights went in: don't try to troubleshoot an alternator problem while you might have a wiring problem that is new to the truck.
RescueDog1
Range Rover L405 (Fourth Gen)
Dec 12, 2024 09:33 AM
rjlsierra
Jul 15, 2023 03:06 PM
USMC_Denver
Jun 15, 2021 03:16 PM
NolaRover504
Aug 12, 2012 01:14 PM
jbgator3
Dec 20, 2010 07:52 AM
