Installing a Traction control in a Disco 1 is possible?
Hello!!!
I have a 1994 Disco I, and as far as I understand, the main improvements from Disco I to Disco II out of the road is that the Disco II has a traction control installed. Since the traction control is based in applying the brakes to the wheel that does not has traction, I think that it could be easy to install a traction control in my car.
What should I do in order to do that? Is the traction control an independent module that I can adapt to my brake pump? or do I have to change the whole brake pump and each wheel sensor? Do I need to install an additional Electronic control Unit?
Comments are welcome!!
Thanks!
Thanks!
joshualaterra
09-30-2011 09:38 PM
gamecockdisco
07-12-2010 09:34 AM
rodrick smith
04-13-2007 07:09 PM
