Installing a Traction control in a Disco 1 is possible?
Old Dec 7, 2009 | 11:19 AM
johnkbl's Avatar
Default Installing a Traction control in a Disco 1 is possible?
Hello!!!
I have a 1994 Disco I, and as far as I understand, the main improvements from Disco I to Disco II out of the road is that the Disco II has a traction control installed. Since the traction control is based in applying the brakes to the wheel that does not has traction, I think that it could be easy to install a traction control in my car.
What should I do in order to do that? Is the traction control an independent module that I can adapt to my brake pump? or do I have to change the whole brake pump and each wheel sensor? Do I need to install an additional Electronic control Unit?
Comments are welcome!!
Thanks!
Old Dec 7, 2009 | 12:54 PM
oysterhead's Avatar
installing detroit and/or trutrac lockers should be MUCH cheaper and better.
Old Dec 7, 2009 | 02:19 PM
jycsalas's Avatar
Yup I agree,
But you would need the DII ECU, ABS Modulator, all the sensors and some how figure out how/ if the new sensors can read the DI hub and make calculate wheel speed etc...
I wouldn't bother.
Plus the SLABS ecu communicates with the Transmission ECU so it can't be done.
Old Dec 8, 2009 | 05:57 PM
Cant do it on your budget.
Just get a good set of tires.
Old Dec 8, 2009 | 07:13 PM
NiteTrain's Avatar
my first thought is that it would be way too much trouble and too expensive. If you really want it that bad just sell the d1 and buy a dII.
michaelfisk
Apr 28, 2018 04:22 PM
gamecockdisco
Jul 12, 2010 08:34 AM
daniep
Jan 26, 2009 01:58 PM
rodrick smith
Apr 13, 2007 06:09 PM
