Intake brake vacuum connection
Old Sep 7, 2022 | 04:56 PM
cappedup's Avatar
Default Intake brake vacuum connection
I noticed the connection at the intake for the brake booster is kinda wobbly.
I suspect it’s a self sealing thing, but it seems too loose for that, even when running.
I can pull the tube and remove the little red ring. The next plastic insert seems pretty tight.
Is there a way to tighten this up? Is it possibly fine?
I’ve noticed that my brake pedal is stiff and less effective for the first 2 minutes of running. Figured it could be a vac assist thing.
Old Sep 7, 2022 | 06:35 PM
nashvegas's Avatar
I think ya just buy a new red / black connector thing... rather than try to tighten it. $45 bucks or so on Amazon Ebay or JLR sources... BTW don't do what I did and hammer it in with a hammer if it's a tight fit. I broke one doing that.
LZN100220L is the part #
I will say the new ones fit pretty snug-ly on the vac tube.
Old Sep 7, 2022 | 07:19 PM
cappedup's Avatar
done. Ordered.
Any trick to getting the old one out?
Old Sep 7, 2022 | 08:36 PM
cappedup's Avatar
Well this is about as tricksy as it gets.
https://landroverforums.com/forum/di...anifold-97502/
Old Sep 7, 2022 | 10:39 PM
whowa004's Avatar
perfect. I've had a new one sitting for months bc I was worried about getting the old one out and had heard a few horror stories..
Old Sep 7, 2022 | 11:43 PM
nashvegas's Avatar
That's utterly brilliant going in thru the throttle body side. I broke mine into 50 small bits of decayed soft plastic ... much cleaner this way.
Old Sep 11, 2022 | 12:39 PM
cappedup's Avatar
Worked like a charm. I stuck together all my 1/2” extensions, with a 10mm socket on the end.
Jammed a rag in the butterfly, put a thin flashlight in there.
Was very careful that the socket was on the plastic fitting before tapping. Didn’t want to bust a hole in the intake. Took maybe 8 taps. Ideally there would be something with a protrusion on the end, so it engages with the hole.
The old one is definitely more worn than the new one. The new one comes with a small bit of blanked off tube, and I can tell the old fitting was leaking by how much of a pop it makes when taking it out.
Anyway, the bad news is swapping the fitting didn’t fix my issue.
After cold starting it takes about 2 mins to get a proper brake pedal. Before that it’s stiff with reduced effect. Issue is my driveway is steep, and I don’t have full brakes at the bottom.
The vacuum line is holding pressure. After shutting off the car I can release vacuum for a couple of minutes.
Is there any way to test the booster itself?
Once going the brakes are fantastic.
Old May 11, 2023 | 12:34 AM
Discorama's Avatar
It's said Saab 55557389 is exactly the same part. $18 ebay, just in case you don't want to drop $45 for the same part with LR part no.
escott16
Nov 23, 2020 11:13 PM
adolfojbonilla
Oct 5, 2019 12:30 PM
adolfojbonilla
Apr 16, 2019 09:17 PM
ctang101
Nov 7, 2017 08:38 AM
me6067
Jun 26, 2015 08:13 PM
