Interior lights arent coming on when doors open...
Old Jan 7, 2013 | 07:21 PM
LADEROUTE's Avatar
Default Interior lights arent coming on when doors open...
As mentioned the interior lights are not coming on when the doors are opened.
The lights do come on however when the switch is engaged to on.
I was looking for a spring bound switch like every other vehicle I have owned but alas, nothing easily viewable in the door sill.
Any help would be appreciated.
Old Jan 7, 2013 | 11:25 PM
Bkreutz's Avatar
You are aware that there are 3 positions on the light? Off, On, and Door. The switch for the light is integrated into the door latch. If you've pushed the switch to "Door" and it still doesn't light the only thing left is the switch or the wiring. Do the lights come on with the other doors (including the rear door)? if they don't then you can probably eliminate the switching in the latches because it's highly unlikely that 5 door latches would fail simultaneously.
Old Jan 8, 2013 | 12:22 AM
And those door switches route through headers to the BCU. The driver door is on one input, and the rest are on the other. So the door switch makes interior light, interfaces with alarm, SLABS, and probably some more functions. Not just the old school jamb switch of the past.
Old Jan 8, 2013 | 11:14 AM
redwhitekat's Avatar
I had this same problem a few weeks ago Lights would not come on when door opened. After a short drive did some errands came back and they were working again. Prob a small glitch Glad mine fixed itself has never happened again
Old Jan 8, 2013 | 03:24 PM
LADEROUTE's Avatar
I looked it over for about 10 minutes and tried all 3 positions on the overhead switch before I came here and posted my query.
Fortunately enough I came out this morning and have had the same fortune fall upon me as redwhitekat - the lights came on when I unlocked the car. It fixed itself!
We'll see how long this lasts.
Either that or I have the first self fixing Rover.....
Doubt it though....
Thank you all for the help and useful information.
If it goes again I will assume it to be something in the BCU.
Savannah Buzz, I'll PM you on that if you don't mind - Regards.
Old Jan 9, 2013 | 07:11 PM
LandRoverDiscoII@JessyDrives's Avatar
Very strange, this happened to me starting about a week ago. Seems that when the car is warm it's less likely to have the issue. Warmth cures my turn signal that takes about three seconds to react if it's a cold morning.
Old Jan 9, 2013 | 08:01 PM
Stalk switch, the grease in it warms up.... there have been posts on it, to replace it or have a go at cleaning the contacts you have to turn the wheel about 90 degrees.
JaJboyce
May 5, 2024 09:04 PM
wynhd
Aug 28, 2012 11:33 PM
dieselgeek
Oct 6, 2009 01:49 PM
yukonridin23
Sep 19, 2009 11:37 AM
Lebowski87
Audio/Visual Electronics
Aug 15, 2005 04:12 PM
