Interlock solenoid and spare cable
Old Aug 14, 2021 | 06:41 PM
kdscott100's Avatar
Default Interlock solenoid and spare cable
Hello, please see the attached picture taken from the driver's seat towards to passenger. There is a cable that has been cabled tied. Can someone advise what this is for?
Trying to get the solenoid off. What a job.... TIA
Old Aug 15, 2021 | 06:58 AM
mollusc's Avatar
Isn't that the emergency brake cable?
Old Aug 16, 2021 | 03:38 PM
kdscott100's Avatar
no. I can see where it could/would connect to the gearbox shift liver but instead, I have the crazy linkage.
Old Aug 16, 2021 | 03:58 PM
mollusc's Avatar
That looks like a D1 shifter handle. The 2004 D2 used cables instead of levers. Does the other end of the cable connect to the CDL nipple somehow (if you have one)?
Old Aug 17, 2021 | 01:47 AM
BriggTrim's Avatar
Hi....Is there an online source accessible for the interlock link assy with the solenoid?
Is there an approach to sidestep this inept thing with the goal that it will not breakdown again and isn't required?
I've effectively taken a stab at disengaging the interlock link, which allows me to move out of park by squeezing the shifter button without squeezing the brake pedal, BUT, it appears to be that I can't eliminate the start key in any event, when it is in park when it is this way.
https://www.7pcb.com/
Old Aug 17, 2021 | 06:38 AM
mollusc's Avatar
The RAVE should have everything you need.
But there are different sets of interlocks. The photo above is looking at the CDL/range assembly, There are shift interlocks related to that. The transmission has a separate shift interlock.
Old Aug 18, 2021 | 11:22 AM
jastutte's Avatar
see if this will help.
Brandon318
Aug 12, 2020 01:35 PM
rOverlanding
Mar 15, 2020 03:20 PM
clayrn
Feb 18, 2020 08:15 PM
ColoDisco
Jul 26, 2011 06:28 PM
jmt
Dec 26, 2007 07:05 PM
