Intermittant Battery Light
Old Feb 19, 2016 | 04:25 PM
  #21
number9's Avatar
I'll probably just try replacing the alternator just to be sure.
+1. Appreciate the sharing of your good troubleshooting procedure as it should help in the future.
Old Feb 19, 2016 | 05:30 PM
  #22
drowssap's Avatar
Sounds like your regulator is about to go.
I don't remember seeing a voltage gauge going from 14 VT to zero volts.
Usually like 12-14 floating back and forth. if they fall drop from 14-0 every ones light would be flickering
Old Feb 20, 2016 | 07:34 AM
  #23
gulfstream69xr7's Avatar
Keep in mind, that the voltage from the main power output is strong and consistent at 14.2-14.4 volts depending on load and RPM. The voltmeter shows there is no change in voltage at the battery of the main output under any of the test environments.
It is only in the warning circuit that the voltage drops out. Again, I am thinking it's the regulator.
seandog
Mar 9, 2011 04:33 PM
FMV
Jun 25, 2008 07:59 AM
37chambers
Jul 8, 2007 05:43 PM
smrfld
Jul 9, 2006 10:21 PM
