Intermittent starting
Old Jan 19, 2018 | 11:03 AM
Buddyp's Avatar
4wd High
Thanks again for all th responses! Today I looked at the ground wire to the frame and found it tight but quite corroded. I took it off and cleaned the frame, bolt, and lead and put it back on. Truck started! Could this be a fluke? I am going to drive the car for a while today and then report back.
Old Jan 19, 2018 | 11:17 AM
CollieRover's Avatar
Possible fluke, hopefully not. Does it restart after you have driven for a while, and has heated up?
Old Jan 19, 2018 | 02:23 PM
Buddyp's Avatar
4wd High
It started right up after it got warm today. I had it on for over 20 minutes and then turned it off then it started right back up. Is there a rhyme or reason to when a starter that is going bad migh show symptoms?
Old Jan 19, 2018 | 03:48 PM
Once mine started going bad, it was like a two day process and it was obvious it needed to be changed. But that is just my experience.If it is the original starter it wouldn’t be a bad idea to change it. I got a new one from Amazon from partsplayer, and I am really happy with it, but it’s only been five months. The motor sounds so much better than the old one. I had just gotten used to how slow and sick it sounded.
Old Jan 19, 2018 | 05:56 PM
mln01's Avatar
I've posted this here before, but 40+ years ago I had a starting problem with my first car, a '65 Mustang. It was solved by loosening the power terminal on the starter, moving it around a little to disrupt any corrosion or deposits, and tigthening it back down. Started right up. High amperage loads need good connections capable of carrying them.
Your solution is the cousin of mine. Good connections in the starter circuit are crucial.
Old Jan 20, 2018 | 03:46 AM
The Deputy's Avatar
Yes, the negative connection is just as important as the positive. Both must be clean and tight, at both ends of cables. A bad ground will cause a clicking sound when trying to start.
My negative cable mounts directly to the bracket below the alternator on engine, not the frame. It does have an intermediate connection to the framework/body of the vehicle right in front of the fuse box, one located by coolant reservoir, for grounding body components.
There is a small body to engine ground strap that runs from the back of the drivers side head to firewall, also. But, if your major ground wire has been relocated by someone to the frame of the vehicle...you should move it back to the engine mounting location by alternator. It's a much better ground location.
Brian.
sflannery1998
Mar 4, 2011 11:17 PM
reno-lr
Nov 18, 2009 08:12 PM
BLeever
Jul 29, 2009 07:36 PM
jpperry
Oct 14, 2008 07:04 PM
baysiderover
Oct 6, 2006 06:58 PM
