Isolator
Old Nov 2, 2021 | 10:17 AM
ronbo's Avatar
3rd Gear
Default Isolator
Fitting an isolator on the battery, do I use a cable on the pos or neg side.
Old Nov 2, 2021 | 10:23 AM
greisinb's Avatar
If you are talking about an isolator connected to a dual battery setup, then the isolator should be connected to the positive side of the battery. Mine is a Keyline "voltage sensitive" type which also has a small ground wire which needs to be connected to the vehicle ground so it knows when to "turn on." If yours is manual you shouldn't have to worry about a ground wire.
If you are talking about a battery disconnect switch, then it should be connected to the negative side.
SeanBaker
Jan 18, 2021 11:45 PM
aemnky606
Nov 12, 2016 11:38 AM
tnk
Jul 21, 2016 11:44 PM
karover
May 28, 2010 07:05 AM
98roverguy
Aug 22, 2007 05:52 PM
