issue with coolant loss
Old Aug 11, 2011 | 05:53 PM
  #21
yloDiscoII's Avatar
I'm going with failing clamp....big bucks no whammies!
Old Aug 11, 2011 | 07:20 PM
  #22
DiscoRover007's Avatar
Just a suggestion. If you can help it, don't ever let the needle get to the red indicator light. The engine is aluminum you risk serious damage.
Old Aug 12, 2011 | 10:15 AM
  #23
wiltone's Avatar
The leak, my good ole Land Rover enthusiasts was....... due to a failing clamp right under the reservoir. The mystery was solved...damn coolant would just "disappear". Thank you again for all your help.
yloDiscoII - NO WHAMMY!
Old Aug 12, 2011 | 10:56 AM
  #24
yloDiscoII's Avatar
Thumbs up
Woohoo! What do I win?!?!
So was it the leak/low coolant causing your temperature gauge to go all whacko or did you get the temp sensor replaced too?
Glad you were able to solve the issue and keep your Disco on the road
Old Aug 12, 2011 | 11:40 AM
  #25
wiltone's Avatar
Exactly!...and I changed the ECT sensor so the gauge is running just fine. Thanks!
cipher982
Feb 27, 2013 08:59 AM
Rover Red
Nov 16, 2010 08:41 PM
BDevilDog
Aug 31, 2009 09:31 AM
ontheroadagain
Mar 27, 2008 08:10 PM
focusontheworld
Dec 1, 2007 11:30 PM
