That jeep bumper is the tits.
Old Jun 22, 2015 | 09:45 AM
  #21
Motorhead1's Avatar
Id be afraid of ripping your frame in two.....hahahahahaaha
Old Jun 22, 2015 | 09:46 AM
  #22
RoverMasterTech's Avatar
Originally Posted by fishEH
Wow. If you don't know the difference between static and dynamic recovery then maybe you shouldn't be welding bumpers on? I wouldn't recover someone with a setup like that. Just not worth my life when welds break and metal goes flying.
The bumper itself is fine, the installation is terrible. My friend has the same bumper on his D1(ArmyRover has a pic of it somewhere). He actually made proper mounts for the bumper so it will bolt onto the frame. He also welded on side trim pieces to make it look good.
At least you list your place of employment so people know where NOT to go.
I didn't understand what he meant, asked him to clarify, so that means I cant weld? Ever see a bumper go flying? No? me neither. Youtube "bumper ripped off" you will see hillbillies ripping bumper after bumper off and no one even gets remotely near danger. When you yank a bumper off it falls to the ground and everyone laughs. You have either never seen a bumper pulled off a car (probably) or . Good for your buddy and his D1. He can attach his bumper however he wants.
I fab and build more cool shiit in a year than you have your whole life. What do you do for a living?
Old Jun 22, 2015 | 09:51 AM
  #23
dusty1's Avatar
let's keep it civil..........knock it off with the name calling. let's, instead, try to keep this thread alive
Old Jun 22, 2015 | 11:03 AM
  #24
Yoops Racing's Avatar
Not my style bumper, I think it is ugly as hell, but cheap cost on a 300 dollar truck. It is his business if he wants to weld it on or not ... sure there is a better safer way....
Old Jun 22, 2015 | 12:37 PM
  #25
thearmlesswonder's Avatar
Talking
[QUOTE=RoverMasterTech;523700]Cant beat it for 270 bucks. I could barely even buy the material to make one that cheap.
Always wondered if people are buying Jeep stuff to put on their rover. Now I know you can and looks good for 300$ ! Welding to to the frame is interesting. Not bad tho
Old Jun 22, 2015 | 02:13 PM
  #26
acg's Avatar
acg
I work for a large commercial truck builder. We frequently caution body builders that welding or cutting the chassis rails certainly void warranty. I am not a material engineer, but I understand cutting or welding undermines the structural integrity of the frame.
There is also a safety aspect. It would be better for the mounting bolt to shear off in the event of a collision, rather than the impact of the welded front bumper transfer to the passengers.
Old Jun 22, 2015 | 02:28 PM
  #27
antichrist's Avatar
Originally Posted by RoverMasterTech
1 10 MM bolt is a bit over 6k LBS shear. so ur buddy has 24000Lbs shear strength.
1ksi = 1,000 psi.
A 10.9 grade 10mm is a bit less than 10ksi shear, so a bit less than 80ksi total (there are 2 shear points per bolt in the bumper mount configuration).
The most common MIG wire (E70) is 12ksi tensile so about 7.2ksi shear per inch (shear strength is about 60% of tensile strength.)
That is, of course, assuming perfect welds, which those aren't.
BTW, is that angle iron? I was assuming it was square tubing, but on looking closer it looks like angle iron. If so, there's very little strength there. Kinda poor man's crush cans.
Old Jun 22, 2015 | 06:27 PM
  #28
mln01's Avatar
I guess this forum doesn't have a popcorn emoticon. Bummer.
Old Jun 22, 2015 | 07:32 PM
  #29
lighting's Avatar
RMT....please can you tell me where you bought the bumper, even if I have to modify and make mounting brackets still a bargain and about fabricating one, forget it, materials alone will be more than $270, add bending, grinding and welding. If there is a issue posting here where to purchase it(conflict with suppliers) just PM ..........thanks
Old Jun 23, 2015 | 07:58 AM
  #30
Originally Posted by antichrist
1ksi = 1,000 psi.
The point I was trying to make was that neither method will break. The paper thin frame rail where the bolt goes through would be the part that rips out before an alloy heat treated bolt or a bead of weld gives out.
