Just bought a Discovery II with some ODBII issues... am I screwed?
Old Aug 3, 2020 | 09:52 AM
jastutte's Avatar
Originally Posted by ocwhale
I am not sure as I just recently got it from the PO. I can ask but he may not know/want to share...
Will drive it some more and see if anything crops up.
check out this link, 2000 Discovery ii Drive Cycle info needed - General Discussion Forum - NCLR - Northern California Land Rover Club, for Discovery Drive Cycles. it can speed up the process for turning the monitors back on.
Old Aug 3, 2020 | 11:56 PM
Seattled2's Avatar
Default Major evap leak code?
If the CE light code is for the Big Evap leak. The Hyundai evap replacement is a perfect replacement .
clips right in:
Genuine Hyundai 28910-22040 Purge...
Amazon Amazon
theres a write up on the forum for it as well. Best of luck!
Old Aug 4, 2020 | 01:02 AM
Discorama's Avatar
PO disconnected the battery probably. I get the same result, when I disconnect the battery for some reason. It needs different drive cycles before all tests have completed, it can take days sometimes. The workshop manual lists the drive cycles required to complete the tests. You can force it when you can't wait for completion with your normal driving. As longs as you don't get codes, there is no reason to worry.
Old Aug 4, 2020 | 12:34 PM
777AIA's Avatar
Interesting title description on that Amazon link:
IRIS USA 1 Tier Large Multi-Purpose Organizer Shelf
Jsivey
Mar 1, 2017 12:40 AM
LandyLoverMissouri
Jan 14, 2016 11:50 AM
archaeology_student
Apr 9, 2013 07:35 AM
rar56
Jan 6, 2012 12:29 PM
bosshogt
Feb 27, 2011 02:42 AM
