Just bought my first rover need some help wont start!
Old Sep 7, 2012 | 03:27 PM
old_coot's Avatar
the head gasket can blow in lots of places..it can leak water into the combustion chamber the outside or crankcase depending on where it blew...same thing goes for oil or compression...the head gaskets do a lot of sealing when they work...the local parts houses have radiator pressure testers. You ought to be able to borrow one and with the engine off pressure the system and see if you can hear where the leak is....It really doesn't matter where it is, If I were doing the repair it would get both head gaskets replaced. the only problem is it could be a cracked head as easily as it is a gasket. First thing to do is find the leak then determine what has to be done to fix it.......Dan
Old Sep 7, 2012 | 03:51 PM
lr2001silver's Avatar
Banned
Correct, you can loose a small section of your head gasket and the engine still can run like a dream. But now there is a weak spot and the big blowout is around the corner. Some have driven like that for a long time and some tear the engine apart and fix it right away. Its a mystery game if you continue to drive it the way it is because you never know when its going to happen. Have you had a chance to download the 'rave'?
Old Sep 7, 2012 | 05:13 PM
jafir's Avatar
I'm pretty sure I've read that a leaking front cover gasket can mix coolant and oil.
Old Sep 7, 2012 | 10:12 PM
old_coot's Avatar
An intake gasket leak around the water crossover can also do it.....that's why I recommended the radiator pressure test to see if he could hear about where the leak was....Dan
Old Sep 7, 2012 | 10:23 PM
allroverthatwhip's Avatar
thanks for the advice guys so i did buy a presure tester and i pressurized the system i took the oil cap off and stuck a hose down in towards the front of the motor and i can hear it driping, its a 2 second delay in between each drip and it sound like its at the front of the engine. now i got another stupid issue ith it now it keeps cranking over when i am trying to start it and the hazards keep going off, as wheel as lights are flashing its like now all of a sudden its not getting spark or fuel.
Old Sep 7, 2012 | 11:26 PM
Banned
Now you need to reset the inertia switch. Something you were doing tripped it.
Old Sep 8, 2012 | 12:40 PM
i downloaded rave but how do you use it?
Old Sep 8, 2012 | 05:33 PM
so im taking the motor apart as wee speak, got most stuff off, i didnt think it was neccessary to take the rad out, im an idiot cause i can't get the impact on teh crank pulley without taking the rad out. so quick advice is this radiator not the stupidest design how the heck do you take it out? someone acctually taack welded the clucth fan on to the waterpump shaft , i had to destroy the fan. stuck on getting the rad out are tehy held in from the bottom?
XxRoverAllOverxX
Apr 15, 2010 07:29 PM
JohnBloom
Mar 15, 2010 01:33 PM
j.dstasio
Nov 26, 2009 08:10 PM
DiscoNoob
Jul 7, 2009 09:52 AM
theworks001
Sep 13, 2008 03:29 PM
