Just got my new shuttle valve o-rings... OUCH
So what is so special about these to charge $50? I know brake fluid is very corrosive and what not, but OUCH! I've never felt more ripped off in my life... ordering a $.25 o-ring for $50. But the peace of mind I guess is almost worth that... key word, almost
We have a business fulling a need to replace these o-rings and is serving a purpose. I believe they should be able to charge for the cost of reverse engineering the old o-rings and finding a supplier.
Ours were leaking and I believe we could agree the resealing with new o-rings is much more cost effective than replacing the ABS Modulator for $1,800.
2003 Discovery with high miles service complete.
http://www.jewellamberoil.com/sales/...roducts_id=247
FalconWorks Part# FW65 includes just the seals (o-rings) and e-clips.
ABS shuttle valve code solution; brake fluid leaks (3 Amigo repair, check your ABS fault codes to be sure).
FalconWorks PART# FW66 includes switches assembly (Genuine WABCO ABS shuttle valves), which is the larger black plastic item pictured with two switches, one on each end, that goes on the bottom of the ABS modulator with new screws to attach it with fresh Loc-tite, and the two seals (o-rings) and e-clips (two for each side, which is an upgrade clip set from the factory clip set).
(Picture from FalconWorks webpage)
Paul Grant
10-01-2014 05:19 PM
bosshogt
02-02-2012 06:52 PM
aarongregor
11-14-2011 08:31 PM
