Just got my new shuttle valve o-rings... OUCH
Old Jan 26, 2013 | 09:44 PM
bballjames's Avatar
Default Just got my new shuttle valve o-rings... OUCH
So what is so special about these to charge $50? I know brake fluid is very corrosive and what not, but OUCH! I've never felt more ripped off in my life... ordering a $.25 o-ring for $50. But the peace of mind I guess is almost worth that... key word, almost
Old Jan 26, 2013 | 09:48 PM
Street Wolf's Avatar
It's a rip off by people who know they can rip you off. Simple.
Old Jan 27, 2013 | 10:47 AM
borchera's Avatar
We have a business fulling a need to replace these o-rings and is serving a purpose. I believe they should be able to charge for the cost of reverse engineering the old o-rings and finding a supplier.
Ours were leaking and I believe we could agree the resealing with new o-rings is much more cost effective than replacing the ABS Modulator for $1,800.
2003 Discovery with high miles service complete.
Old Jan 27, 2013 | 01:09 PM
aarongregor's Avatar
I also felt like I was robbed when I had to buy my O rings from them, they are a total rip off. I can understand wanting to make a profit but taking advantage of people just because you can is just bad business. Karma will come around on them!
Old Jan 28, 2013 | 08:31 PM
kfx4001442's Avatar
Where do you get them from? My 3 Amigos are on and I'm getting some shuttle valve error code or something like that. Might be what I need to do.
Old Jan 28, 2013 | 09:06 PM
Rover_Hokie's Avatar
http://www.jewellamberoil.com/sales/...roducts_id=247
FalconWorks Part# FW65 includes just the seals (o-rings) and e-clips.
ABS shuttle valve code solution; brake fluid leaks (3 Amigo repair, check your ABS fault codes to be sure).
FalconWorks PART# FW66 includes switches assembly (Genuine WABCO ABS shuttle valves), which is the larger black plastic item pictured with two switches, one on each end, that goes on the bottom of the ABS modulator with new screws to attach it with fresh Loc-tite, and the two seals (o-rings) and e-clips (two for each side, which is an upgrade clip set from the factory clip set).
(Picture from FalconWorks webpage)
Old Jan 30, 2013 | 05:48 AM
jfall's Avatar
Worth it easy.
did you get those rings in?
Paul Grant
Oct 1, 2014 05:19 PM
bosshogt
Feb 2, 2012 06:52 PM
aarongregor
Nov 14, 2011 08:31 PM
wesk
Feb 17, 2008 10:22 PM
majrmike
Oct 9, 2007 03:13 PM
