just installed my winch...
Old Aug 11, 2015 | 07:54 AM
  #31
04duxlr's Avatar
That cable has been on there since it was installed at the factory in 2004, but if it does ever fail I will consider building my own using heat shrink on the lugs. I prefer soldered connections to crimped, but in this case it looks like the crimped connection is more than adequate.
Old Aug 11, 2015 | 09:14 AM
  #32
mln01's Avatar
Originally Posted by LRlax11
I'm running into the same problem as you.. just bought my new smittybilt X2O 10,000lb winch but I can't get the damn thing mounted in my terrafirma bumper because of that piece of metal running in the way.. I was about to cut it out but i thought I'd take to the forums to make sure that's the way to do it..
Originally Posted by drowssap
yes that piece need to be cut out , something TF does not tell you
is it okay to it that piece out? what structural purpose does it have..
LRlax11, yes, you need to cut out the piece of steel that sits behind the lower edge of the grill in order to mount a winch with the Terrafirma bumper. As drowssap said that is not something TF discloses clearly; they make only veiled references to it and the dealers are no better.
I encountered the same question six weeks ago and looked carefully at the structure to try to determine whether or not to proceed with cutting it out. I came to the conclusion that it serves no significant structural purpose and went ahead with the cut. A $14 HF angle grinder made quick work of it.
The Terrafirma may be the only bumper that requires the piece to be removed because it is also the only winch bumper that mounts so close to the body (which is why many of us bought it). The ARB mount positions that bumper several inches farther forward and also lower, avoiding any interference with the grill.
Old Aug 12, 2015 | 06:45 PM
  #33
Rover_Hokie's Avatar
FYI, my Tactical Rovers front bumper also required cutting the support to install the winch.
Rover_Hokie
Apr 23, 2015 11:12 PM
Funtogun
Jan 5, 2015 05:45 PM
dr.brillo
Jun 8, 2011 06:29 PM
bobm
Feb 21, 2010 10:30 PM
blast20
Feb 15, 2010 10:25 AM
