K&N air filter for v8 disco?
The general idea is no, because you won't get the advertised mpg/power boosts (it is a 4000+ pound brick and tiny v-8 geared for off road use), and the filter allows more oil and dust to enter the MAF sensor and the oil system eventually. The KN filters warranty is void if used off road I have been told. As a new owner of an older D1, I also went down this path, took out the old air box, put on the cone filter, etc. Not a change I could see at the pump, and it was a bit noiser under the hood. Put old system back.
You will also get other reponses that take an alternate view. IMHO upgrade money is better spent on things like Ultra Gauges, plugs and wires, oil changes; not performance chips and the like.
