Keys
Old Feb 16, 2019 | 01:04 PM
Mike53's Avatar
Default Keys
Dear sirs,Thanks again on the input on the head gasket operation,I have a nother problem.I have one key for my disco and the buttons on the key phob are shot.I found on eBay you can get brand new ones and you can have them cut .Ebay says that they will work.But don’t you have to send your vin # to Land Rover to get the right code so the key maker can cut it correctly and what about the programming process for the face board does that have to be programmed can the key guy do this after the key code is sent to the key maker or does it have to be done by the dealership?Does anyone know?Thank you
Old Feb 16, 2019 | 01:54 PM
abran's Avatar
The vehicle and new remote have to be at the same location for someone to code it. Your remote needs to be 315 mHz, make sure you don't get a 422 or whatever else is out there.
Old Feb 16, 2019 | 02:48 PM
zuke's Avatar
I am betting that the microswitch on your circuit board is broke .You can get a pair of new ones on eBay for 10 bucks then have it installed for another 20 bucks. I did that and put a detailed write up on it.
Old Feb 16, 2019 | 02:49 PM
Mike53's Avatar
Default Keys
Thanks a million!
Old Feb 16, 2019 | 03:21 PM
mollusc's Avatar
the ebay ones are often just the plastic shell. if your circuit board and the switches on it are still fine then all you need to do is change the outer piece and have the key shank cut by any independent locksmith.
Old Feb 24, 2019 | 01:19 PM
FirstRoverDisco's Avatar
I purchased a key from remotekey.co.uk. It came with a key / FOB and programmer for about $150, $30 of which is a deposit that gets refunded when you return programmer. I received a few days ago, it works great.
https://remotekey.co.uk/
Old Oct 14, 2019 | 08:30 AM
ChrisLyon's Avatar
That's far away from us, i consider hiring a local mechanic to take car keys out whenever i face issues like locked keys in car or lost keys.
Old May 25, 2020 | 08:00 AM
AntonyGuill's Avatar
Thanks for your support guys, i was a bit puzzled where to go for the keys. But you all have shared a way to get the keys. I will contact locksmith bronx to provide me new keys at cheap.
Old Nov 27, 2020 | 05:13 AM
JUKE179r's Avatar
I repaired my fob circuit board with a $0.13 micro tact switch from Mouser.com...
part #PTS636 SK25J SMTR LFS … https://www.mouser.com/ProductDetail...VU43xmeLp5QQ==
or more durable switch...
part #RS282G05A3SMRT ... https://www.mouser.com/ProductDetail...ipiNSAIl%252BG
mr. choodles
Feb 6, 2021 04:48 PM
jeffery212
Aug 31, 2018 09:41 PM
bballjames
Apr 9, 2013 10:51 AM
wblake
Oct 21, 2007 09:29 AM
dbwarren
Nov 12, 2006 12:41 PM
