Knock Sensor Help911
what location was the wire damaged in the car? I have checked everywhere but behind the pulley and don’t see any damage. Should I take apart the harness?
mine was broken behind the pulleys, but had brittle insulation the whole length down. I unplugged the sensor and pulled the whole wire to the top to fix it. You can also ohm it out to see if it’s broken. I unwrapped and went into the fuel harness a little ways until I found original wire that wasn’t brittle to splice into.
