Knocking.... Power Steering Pump?
Old Mar 25, 2010 | 05:59 PM
Natur4lKonc3pt's Avatar
3rd Gear
Default Knocking.... Power Steering Pump?
I recently heard a knocking sound coming from the engine of my '04 Disco. I searched the forum database and didn't really find any similar cases. Here are some things I noticed.
- Sound is not as metallic sounding as lifters
- Sound seems to be coming from top to mid driver side engine
- Power steering fluid bubbles back into reservoir when you turn the wheel
- When steering is under load sound is quieter sometimes eliminated
- Knocking increases in both speed and sound with rpm's of the engine
- Steering Fluid isn't burnt but when I checked it was at the Min. line
- New oil & filter as of today 10W/40
- approx. 88,000 miles on the truck
Has anyone had similar problems or know what this may be? Is this the pump? Bad hose? Need a bleeding? I'm not sure. Thanks Everyone!
Old Mar 25, 2010 | 06:16 PM
First remove your serp belt, start the engine and see if the noise is still there.
Only run the engine for a few min without the belt on.
If the noise is gone then turn the engine back off and spin every pulley by hand, any noise?
Report back what you find.
Old Mar 25, 2010 | 07:22 PM
Don't worry about others experiences, next time you hear it, get under the hood and isolate the noise so we might better help you.
Old Mar 30, 2010 | 04:54 PM
3rd Gear
It is confirmed. The Power Steering Pump is shot. Has anyone replaced this that may have some tips?
Specialty Tools?
Anything that should be removed for the change?
Anything that you recommend not removing?
Any other easy fixes/repairs I might think about while I'm in there?
Does anyone have any good "how to" links
Old Mar 30, 2010 | 05:07 PM
lipadj46's Avatar
Many of us have changed the pump. No tips, it's easy, follow the Rave CD. The clutch fan nut is 36mm.
Here are a couple cheap 36mm wrenches:
http://www.northerntool.com/shop/too...2595_200322595
http://store.harryepstein.com/cp/Facom/004536.html
Old Mar 30, 2010 | 05:29 PM
3rd Gear
I'm new to the forums as well as being a Land Rover owner.
What is the Rave CD?
Old Mar 30, 2010 | 05:51 PM
lipadj46's Avatar
The free Land Rover shop/repair manual. Search and ye shall find.
Old Mar 30, 2010 | 06:24 PM
okdiscoguy's Avatar
In my sig. Free download.
Old Aug 6, 2010 | 09:38 PM
archebald23's Avatar
Specialty Tools?
Power steering pulley remover tool
Large open end adjustable or non-adjustable wrench to fit the pulley remover tool
Set of 3/8-inch drive sockets
3/8-inch drive ratchet
3/8-inch drive short extension
Set of line wrenches
Important: let the engine cool off completely.
Old Aug 7, 2010 | 07:34 PM
lordmorpheus's Avatar
Forget the power steering pulley remover tool. The pulley on these engines are bolted to the flange at the end of the shaft. They aren't press fit like a lot of other vehicles
johnnyjohnny
Sep 26, 2019 09:37 PM
joshjellel
Feb 16, 2015 10:53 AM
losinov
Mar 21, 2011 08:57 PM
FargoDisco
Jun 9, 2009 08:58 PM
treho54
Sep 19, 2008 11:29 AM
