Landrover Discovery II problems starting
Old Nov 16, 2011 | 01:02 PM
Bjornvinterbarn's Avatar
Default Landrover Discovery II problems starting
I am having a problem with my Land Rover starting up I was driving it and when I went to park it I had my windows down but they would not go up I turned the car off and tried to turn it back on and it would not start or go into any gears and windows would not go back up, Checked all fuses and power supplies 2 fuse panel everything seems to be ok, dont know where to go from there.
Thank you for your time and help
Old Nov 16, 2011 | 02:56 PM
Does engine turn over at all? If not, you are immobilized. With other problems you report, might be a bad battery and or a problem with the BCU (body control unit). You also have a fuse box under hood, and it has large bolt down fuse links that can be checked with a meter. The BCU drives the starter relay directly, and controls lots of other parts. Muliple fuses are involved.
Old Nov 16, 2011 | 04:06 PM
handsome rob's Avatar
It could be just as easy as a bad battery conncection, mine did that to me a couple of times and just tightening teh terminals fixed it.
Old Nov 16, 2011 | 04:26 PM
Andrew Davies's Avatar
Likewise, mine would just cut out. Switch the engine off and back on and nothing. I thought it was a major fuse to start with but it turned out to be a bad connection from the main neg battery cable. Some vigorous wiggling got it running again until I could change the cable.
Old Nov 9, 2013 | 09:09 AM
nolarover16's Avatar
Having a problem with starting my Disco ii... after driving all week i parked at the house yesterday and this morning it will not turn over. It sounds as if it is trying to crank over but nothing happens. Almost sounds as if fuel is out however ther eis more than hlaf a tank... HELP!
Bakari75
May 9, 2013 02:00 PM
key guy
Oct 16, 2011 07:56 PM
St3fanPL
Freelander
Mar 18, 2011 02:23 PM
Unshriven
Feb 28, 2010 01:29 PM
