98 discovery starting problems
Old May 8, 2013 | 04:03 PM
Bakari75's Avatar
6th Gear
Default 98 discovery starting problems
Ok So My Alternator went Bad about A Month Ago and In That Month Ive Been Taking My battery Up To Advance Auto parts and charging it for 30 mins about 2 or 3 times a aday...so last night i was driving and my battery died because i was using my lights so i had a mini portable jump starter and charged it for about 5 mins then started it and it went for about 1 more mile then it died again..i plugged the chrger up again and kept trying to start it but the car would turn on but it wont start up..also i put a new alternator on yesterday and charged my battery for 30 mins but still no start up...i opend the hood and asked a friend to turn the key while i listen for any sounds under the hood and everytime he turns the key i hear a small pop/click noise to the right of the winsheild fluid tank...is this my starter thats not workin? someone help please thanks
Old May 8, 2013 | 05:33 PM
Does sound that way. But you could have corrosion on the battery terminals, the big cable on the starter, and if you follow the negative cable down beside the radiator you will find a bolt where it bonds to the frame. All of these spots need to be clean and tight. Also, in the underhood fuse box, there are two bolt down lugs at the front of the box, these need to be clean and tight as well.
Old May 8, 2013 | 07:35 PM
Bakari75's Avatar
6th Gear
so basically just clean them?
Old May 8, 2013 | 07:53 PM
Electrical connectors that carry high current only need a small bit of corrosion to cause a drop in voltage that would prevent operation. Use something on the order of a small wire brush, steel wool, fine sandpaper, a green scrubby pad. They should be bright and clean, and tightened.
Old May 9, 2013 | 06:47 AM
gprtech's Avatar
Try charging the battery fully.
Old May 9, 2013 | 08:56 AM
SSL9000J's Avatar
If there's any corrosion on the battery or terminals, you can pour warm water over the whole thing to clean it off. (It won't hurt the components or short anything out, don't worry.) Auto parts stores sell battery terminal cleaner in a little spray can, that works pretty good as well.
Old May 9, 2013 | 02:00 PM
Bakari75's Avatar
6th Gear
i was thinking that might be the case
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
Bjornvinterbarn
Nov 9, 2013 09:09 AM
Unshriven
Feb 28, 2010 01:29 PM
hsmatharu
Freelander
Sep 14, 2006 04:56 AM
finetrophywife
Aug 5, 2005 03:40 PM
