Landrover won't start any ideas???
Old Apr 5, 2011 | 12:01 AM
mx468's Avatar
Originally Posted by Wolf
Sounds like you might have a corroded cable, either ground or positive. Sometimes if there is a split in the insulation it will allow moisture in to corrode cable. Check the connections to the block and starter. you may have a bad cable.
Hey Wolf I checked my positive cable and it was corroded about 2 inches back. Cut and reinstalled to a new battery terminal and now my rover starts. Thanks for the suggestions.
Old Apr 5, 2011 | 07:41 AM
Wolf's Avatar
When changing the connector you should only use a solder type connection not a clamp style. Use the anti-corrosion rings under the terminals and coat connectors once cleaned and installed. This will prevent battery gases from corroding the connections.
Old Apr 5, 2011 | 07:51 AM
photocrimes's Avatar
I was cleaning up my cables the other day and then it all became clear. The ground cable still had it's part# tag on it. Printed across the bottom "Lucas"
Lol, now I'm not surprised.
Old Apr 5, 2011 | 07:53 AM
Wolf's Avatar
Sounds like it's time for a new cable. Your lucky it has lasted this long!
ToddD
Feb 11, 2015 09:44 AM
stock d2
Feb 4, 2015 08:58 PM
tigertrakstar1
Mar 5, 2014 04:13 PM
Cliff
Dec 28, 2013 09:33 AM
