Leak from throttle body heater... replace or tighten?
Old Dec 11, 2015 | 08:40 AM
Paul Grant's Avatar
I didn't see the door lock rod but do think the heater is a cool alternative.
I guess I'm just tired of the race to the bottom with everything being about one thing and one thing only, how cheap it is. We buy stuff cheap from the local parts store and think we're getting a deal until we find out the part doesn't fit. We want the best price but when we discover the item isn't built as well or doesn't last as long we're pissed at the manufacturer. Shortcuts and shoddy workmanship abound these days and, in fact, get rewarded in the quest to save money.
To me, it's just nice to see someone take the time to offer a solution that, as I said, will probably last longer than the car itself.
Old Dec 11, 2015 | 09:14 AM
drowssap's Avatar
tis true
Old Dec 11, 2015 | 09:17 AM
batard's Avatar
I love this kind of thing because it addresses the biggest durability issue with these Rovers: plastic pieces and parts in and around the engine block. I don't care if it's expensive – it's great that the option exists.
Old Dec 11, 2015 | 10:47 AM
gbclowes's Avatar
4th Gear
Originally Posted by Alex_M
Definitely replace those spring clamps, they're sh*t. Personally I'd replace the gasket as easy as it is to get to, or even just bypass the damned thing. I've had mine bypassed for a year and I've never had an issue daily driving it in temps ranging between 90 degrees and -10 degrees and everything in between.
I'm going to do the bypass, but I live in South Florida where icing is never an issue. Once I do the bypass what do I do with the nipples coming off of the throttle body heater? Do I cap them, plug them or do nothing?
Old Dec 11, 2015 | 10:48 AM
gbclowes's Avatar
4th Gear
Originally Posted by Frank4
Bypass that that thing. It's a piece of garbage and it WILL start leaking again.
I am doing the bypass on my '02 D2. What do I do with the nipples on the throttle body warmer once bypass is done?
Old Dec 11, 2015 | 10:49 AM
Alex_M's Avatar
Nothing, just leave them open.
Also, your inbox is full. You need to clear out some messages if you want to receive any more from anyone.
Old Dec 11, 2015 | 10:54 AM
gbclowes's Avatar
4th Gear
Thank you Alex for the throttle heater answer as well as the inbox tip! Have a Grateful day!
Old Dec 11, 2015 | 08:02 PM
dr. mordo's Avatar
Originally Posted by batard
This is a very common thing. You have two basic options:
1) Bypass the throttle body heater plate entirely.
2) Replace the assembly.
If you opt for the second choice, I'm pretty sure Atlantic British has a kit for it. Shouldn't be incredibly expensive - just make sure you have a 5.5mm driver.
I very much disagree.
The third option is to take it apart, clean it, and reassemble using RTV instead of a gasket. Costs almost nothing, and will likely hold forever.
There is absolutely no reason to replace the whole assembly.
Old Dec 13, 2015 | 08:42 PM
MyRoversNameIsCarl's Avatar
Thank you for the replies!
Just to let you know... When replacing the heater plate last time I used RTV on both sides of the supplied gasket. None of the bolts were loose when I checked.
I looked at it yesterday and one of the spring clamps literally slid off without unclipping it... No leak appeared to originate from the gasket area so I will try to get some wormgears and see what happens. I'll update when I replace the clips.
Chrisinhouston
Mar 8, 2020 03:54 PM
JRover83
Sep 18, 2012 05:37 PM
Classklown90
Sep 16, 2010 02:59 PM
Luv2Disco
Oct 20, 2008 04:08 PM
Rich 00 DISCO
Jul 3, 2008 09:09 AM
