Leaking O-Ring from Heater Pipe at Intake Manifold
Old Jan 17, 2020 | 10:49 PM
Sixpack577's Avatar
If it leaks, you'll need to tap or helicoil the bolt hole.
Sounds like it has stripped threads.
You're fortunate it's holding it in tight enough.
Old Jan 18, 2020 | 01:27 PM
CanadianRover's Avatar
Don’t scare me like this... Let’s all say a prayer.
Old Jan 18, 2020 | 01:35 PM
Sixpack577's Avatar
If it does, it's actually a simple repair, nothing to be overly concerned about.
Cross that bridge if you come to it.
Old Jun 15, 2022 | 05:35 PM
girlfriendboughtarover's Avatar
edit: solved - bolt is M8 x 1.25
Does anyone know the size of the bolt that holds the heater pipe into the intake?
finishing a head gasket job and I don't know where I put it. Don't really have bolts lying around to test it either. Thanks
Last edited by girlfriendboughtarover; Jun 16, 2022 at 06:10 PM. Reason: Solved issue
keninnc
Nov 17, 2019 10:32 PM
Charlie_V
Jun 7, 2016 10:34 PM
04duxlr
Sep 29, 2014 09:18 PM
Reza
Feb 23, 2014 04:49 PM
ccasseljr
Mar 29, 2011 05:50 PM
