Parking brake light on
Old Jun 13, 2022 | 08:28 AM
keninnc's Avatar
Default Parking brake light on
2003 North American D2
My parking brake light remains on. I've tried the easy fix of spraying WD-40 under the boot in the center console and sprayed everywhere I could where the cable attaches at the drum after the transferase.
Any ideas where I should go from here?
Old Jun 13, 2022 | 05:14 PM
mln01's Avatar
Hey Ken. Check the brake fluid level.
The brake warning light also illuminates if the brake fluid is low in the master cylinder reservoir. It could also illuminate due to a faulty switch, either for the hand brake or the master cylinder fluid level.
Old Jun 13, 2022 | 06:25 PM
Extinct's Avatar
Also illuminates for a hard abs sensor fault - hard as in zero signal.
Old Jun 15, 2022 | 06:16 AM
keninnc's Avatar
Brake Fluid low. Added some and light went off.
Thanks for the help
Old Jun 15, 2022 | 08:44 AM
mln01's Avatar
Great. Next question -- why was the brake fluid low?
Most commonly it's the rubbery seals at the master cylinder. Does anything look "wet" there?
Old Jun 15, 2022 | 05:57 PM
keninnc's Avatar
The reason the brake fluid was low was because of user error.
I had replaced the brake booster a couple of months ago and I think I just barely filled it up to the minimum line.
Old Jun 15, 2022 | 06:25 PM
mln01's Avatar
In this case pilot error is a good outcome! It means there's likely nothing else wrong, i.e. no leaking master cylinder.
LR2driver
LR2
Jan 9, 2022 07:48 AM
twcord
Sep 30, 2021 08:17 AM
Robert Tripp Norwood
Range Rover Classic (1st Gen)
Jan 24, 2021 08:02 PM
jmartosella
Range Rover Evoque
Dec 26, 2020 07:10 PM
bamaboy473
Aug 3, 2012 06:33 AM
