Leaking rear seals
Old Nov 7, 2006 | 11:13 PM
keverson's Avatar
Default Leaking rear seals
I own a 99 Discovery I and have started a significant oil leak. The bottom of the disco is covered in oil. I crawled under to see that the oil pan and plug is ok. Tranny is all wet. Signs to me that it is the rear seals. I prefer to do it myself and have skills and time to do it right. Just not to familiar with proceedures on this one. Any help? I am too cheap to buy a shop manual. Quickly, it's starting to snow. Say ya to da up, heh!
Old Nov 8, 2006 | 11:12 AM
Default RE: Leaking rear seals
Are you saying it is the rear engine seal or rear tranny seal, what fluid are you leaking?
Mike
Old Nov 8, 2006 | 11:29 AM
keverson's Avatar
It is the rear engine seal. I am leaking engine oil.
Old Nov 8, 2006 | 12:38 PM
Thats a good size job, is it something you can do at home? Go you have a floor jack to handle the tranny and t/case?
If so, I would suggest you inspect and replace all the other seals fron the front tranny thru the t/case as needed while you have it apart.
Other wise it is not a technicly difficult repair.
Good luck
Mike
Old Nov 9, 2006 | 05:08 AM
kylle08's Avatar
Worn piston rings also causes crankcase pressure which consequently causes oil leaks at and seals. If you already had a worn out rear seal, better replace it soon.
2K Disco II
Mar 24, 2016 08:11 AM
treant985
Aug 5, 2012 06:23 PM
ljdiscovery
Feb 27, 2010 07:11 AM
98roverguy
Sep 20, 2008 07:25 AM
ljdiscovery
May 22, 2008 10:30 AM
