Leaving Rover parked for 3 months (battery?)
Old Nov 4, 2011 | 12:42 PM
nahtanoj's Avatar
Default Leaving Rover parked for 3 months (battery?)
alright, in my line of work i leave the country for 3-4 months at a time. the car will not be accessible to anyone during this time. i've read the horrors of a battery dieing and immobilizing the car and i don't want to be stranded at midnight the day i get back with literally no way of getting the car to a dealer to get it going again.
options: disconnect the battery. how can i do this without immobilizing it?
buy a solar battery tender. will this 'f' my battery? i have no experience with them.
fingers crossed the battery stays alive that long.
just looking for some direction and experience with this. i have read this article: Security and Alarm System Operation & Diagnosis on Range Rover 4.0/4.6/P38A and i don't want to go through all this in the dark trying to get home.
thanks,
jon
Old Nov 4, 2011 | 01:56 PM
01d2Jeff's Avatar
Will the vehicle be parked someplace where you could utilize a "trickle charger"?
Old Nov 4, 2011 | 03:11 PM
Solar chargers work, but don't get the smallest size ($20). However for it to work, the cigar lighter must have power when engine off and keys removed. You'll have to check that.
Old Nov 4, 2011 | 05:41 PM
nahtanoj's Avatar
no ability to plug in a trickle charger. it'll be in a locked parking lot in the middle of nowhere. i was looking at one of these: Solar - Batterytender.com
i don't think the cigarette lighter has power with the key off, so i'd just run wires straight to the battery.
the only other option i see is disconnecting the battery, but how would i do this safely without risking immobilization?
thanks
jon
Old Nov 4, 2011 | 08:17 PM
5 watt one should do it. When you run wire to the battery or fuse box, insert an in-line fuse (5 amp) on the hot wire that connects between new stuff and the existing truck wiring.
Old Nov 4, 2011 | 09:21 PM
As long your door lock works (with the key) you will not be locked out if the battery goes dead, unless you "super lock" the truck when you park it, which is a very bad idea.
If you unhook the battery you will screw up the alarm.
If you have a good battery and it is fully charged when you park the truck it will not go dead in 3 months.
I would use the solar charger hooked directly to the battery with it placed on the dash for maximum sun exposure and run the wires under the hood out of sight.
If you are parking it where it is going to snow try and park it facing south so the sun melts the snow off of the windshield and the charger gets full sun.
The cigarette lighter in Land Rovers does not have power with the key off.
Old Nov 4, 2011 | 09:26 PM
nahtanoj's Avatar
thanks for the input guys. i'll go with the solar battery tender. i'll need it on more than one occasion, so i may as well.
jon
tyshooter2000
Oct 10, 2014 06:57 AM
Rovin4life
Apr 19, 2011 09:25 PM
Rob V.
Dec 17, 2005 03:13 PM
Rob V.
Dec 14, 2005 03:27 AM
SoCal Blue
Apr 7, 2005 08:59 PM
