Little puddle
Old Mar 19, 2020 | 01:39 AM
Wheelspin's Avatar
Default Little puddle
Hi team if you can imagine your disco is a Japanese car on a hot day, that’s where the leak is, like the aircon hose is making a mess
a small puddle passenger side at the front
I’ve only had it 3 days a 04 v8 126k, was cleaning it inside at the time and couldn’t smell a thing, it had had a service the day before, if anyone can give me ideas to check I’d appreciate it
Old Mar 19, 2020 | 03:07 AM
JUKE179r's Avatar
Welcome to the forum.
It could be some or all 4 things... a bad door seal, the air conditioner condenser drains are blocked, leak from the windscreen or the sunroof drains are clogged.
Easy way to check and clean condenser drains... https://landroverforums.com/forum/di...40/#post527831
Old Mar 19, 2020 | 04:11 AM
mln01's Avatar
Wheelspin, are you saying the puddle is on the ground under the truck or in the front passenger seat footwell inside the truck?
Old Mar 20, 2020 | 02:06 AM
Wheelspin's Avatar
sorry new to this stuff, it’s on the ground , and since there is a bash plate I’m struggling lol
Old Mar 20, 2020 | 08:46 AM
mln01's Avatar
I don't know what a "bash plate" is, but clear water on the pavement is perfectly normal. It's condensate from the air conditioning system. The A/C system works exactly the same in all cars, regardless of whether or not they are designed or built in Japan.
Old Mar 20, 2020 | 10:05 AM
Richard Gallant's Avatar
@Wheelspin Ok let's make this easier
In the image below is the leak :
  • at the forward most door seam
  • near the middle of the front tire
  • or further forward, the front edge of the tire or more forward
Old Mar 20, 2020 | 11:54 AM
Sixpack577's Avatar
Sounds like a coolant leak dripping on to the factory plastic skid plate. And that he can't see the leak, or exactly where it's coming from, because it's dripping on the top of the skidplate, then running to the lowest point and dripping on to the ground.
I don't know of any D2 skidplate that would cover where the ac drips.
I wonder if there is coolant in the truck, or just water?
Old Mar 20, 2020 | 12:14 PM
@Sixpack577 that was my thought too - so rad hoses, rad, or coolant return line
Old Mar 20, 2020 | 12:18 PM
mollusc's Avatar
I can't work out from the OP's posts if he has ever described the qualities of the liquid that is leaking. Oily, greasy, soapy, viscous, odour...?
bennycisco
Mar 5, 2018 01:59 PM
Sarasota Rover
Jun 27, 2017 06:38 PM
mirepoixmatt
Jun 18, 2017 03:25 PM
zeroone
Jan 13, 2015 11:44 AM
newtolandie
Jan 2, 2012 05:38 PM
