Lock problems 2004 Disco
Old Feb 9, 2012 | 03:47 PM
GadgetRick's Avatar
Default Lock problems 2004 Disco
Ok, haven't logged in/posted here in a looooooooooooong time. Sorry.
Anywho, got a 2004 Disco (Bea's her name) and the driver's side rear door will not unlock/lock using the key or the button on the dash. Can manually unlock/lock the door, however. All other doors seem to be ok.
Before trying to get into the door (and breaking something), I figured I'd ask and see if this might be as simple as an arm (or something) slipping off. If not, I'd rather have an idea so I can order any parts I (may) need.
Thanks in advance!
Old Feb 9, 2012 | 04:31 PM
jafir's Avatar
Does it look or sound like it's doing anything when you lock or unlock the doors?
Old Feb 9, 2012 | 05:25 PM
GadgetRick's Avatar
Well, it does unlock/lock the other 3 doors so I have to say yes. However, I've not listened specifically to the door in question to see if there's anything happening inside. I'll have to do that as soon as I go out there.
Old Feb 9, 2012 | 05:40 PM
thebloody's Avatar
Sounds like your actuator has given up the ghost. Read though this, if you are willing to do the work it's around a $5 fix: https://landroverforums.com/forum/di...-repair-30164/
Old Feb 9, 2012 | 05:51 PM
GadgetRick's Avatar
Thanks a bunch! I'll read it and figure it out.
2004disco2hse7
Aug 10, 2015 10:59 AM
TJ Ranfranz
Oct 31, 2014 06:52 AM
jakethekid
Oct 3, 2014 09:22 AM
kpl1228
Aug 19, 2012 05:33 PM
rekogniz1
Oct 5, 2009 05:51 PM
