Locked out of discovery 2001 dead battery
Old Jun 29, 2013 | 03:22 PM
discovery2001's Avatar
Default Locked out of discovery 2001 dead battery
Accidentally left the lights on and when I came back there was still a little bit of power but the door would not unlock. Whenever I would click the unlock button the light inside would turn on but only for a second. The key doesn't even fit into the hole so I couldn't get in that way. Called someone to try to unlock from the outside but he wasn't able to unlock the door using the wedge and rod. My dad wants to break a window but I hope that won't be necessary. I read somewhere that the passenger door has a secret lock or something like that but I'm not sure about that. Is there any way to get into the vehicle?
Edit: Nvm got inside
Old Jun 29, 2013 | 03:49 PM
You are in trouble!!
If you want some help with this, PM me your Dad's number and I'll be glad to walk him thru what to do.
Old Jun 29, 2013 | 09:18 PM
NickAdams's Avatar
Connect jumper cables under truck at starter connection to positive terminal of battery. Good luck!
Old Jun 29, 2013 | 10:20 PM
zombiedisco's Avatar
are you going to tell us how you got inside, to help others in the future with similar issues?
Old Jun 29, 2013 | 10:23 PM
caymandrew's Avatar
+1
Old Dec 16, 2020 | 01:28 PM
Norma Jean Saylor-Cuilla's Avatar
Default Locked out Range Rover 2003 dead battery
Originally Posted by caymandrew
+1
help how do you get in if locksmith can’t even open ?
Old Dec 16, 2020 | 01:45 PM
nashvegas's Avatar
You will need to go underneath the truck, hook a battery charger up to the starter motor area (careful -- google it to see how) to get voltage to the vehicle.
Theoretically if nothing is screwed up, and it's just a dead battery, you should then be able to unlock.
BTW - do you not have a key to unlock the drivers door manually?
Old Dec 16, 2020 | 08:04 PM
JUKE179r's Avatar
Hopefully OP was able to get into his truck 7 years ago.
georgep
Jan 11, 2022 02:14 PM
brigadier_dj
May 31, 2014 07:06 AM
sfxgamer
Dec 24, 2010 12:58 PM
zqwester
Feb 8, 2009 07:02 PM
