Locked Rear Passenger Door
Old Aug 25, 2025 | 09:49 AM
bjordan's Avatar
After looking online, I found the answer to my question: The Nanocom will disable the Superlock feature of the Discovery II. I snuck away from work for a few minutes and disabled the superlock feature, but the door still will not open.
At this point, I am down to seeing from Extinct if there's a way to destroy the actuator that's installed and get the door open.
Or, I *think* remove the rear seat and door trim and cut through the lip covering the door striker plate and use a bare hacksaw blade to cut through both ends of the striker plate (hoop). I've seen photos of this done on another LR model.
Or, seeing if anyone has another option to consider.
Old Aug 26, 2025 | 04:41 AM
Extinct's Avatar
You actually should be able to lock and unlock using the nanocom, is in the BCU section under diagnostics. You should be able to hear it do each function separately. Lock-superlock-unlock. Start with unlock to see if you can get the door open. Also, now that I am thinking about it, if you look at the wiring diagram, it should be possible to jumper the wires to get it to unlock. I don't remember the pinout details but if you put 12v in the right wires it will unlock. That is how I bench test mine.
Old Aug 29, 2025 | 02:31 PM
bjordan's Avatar
I as finally able to get to the Land Rover and with the Nanocom, I unlocked all the doors probably 15 cycles. Still wont open.
Extinct, if you get me some pics of the actuator and how to take it apart and get the mechanism to open, please do. I can try the jumper wire, but I don't have a schematic - do you have one, or tell me what pins I need to jump?
Other wise, I am down to trying to saw the striker plate hoop with a bare hacksaw blade.
Thank you!!
Old Aug 30, 2025 | 07:06 PM
Extinct's Avatar
Here you go:
Old Sep 2, 2025 | 10:01 AM
bjordan's Avatar
Originally Posted by Extinct
Thank you Extinct! That is awesome. I am not sure if I can manipulate my hands into the tight spaces with the door closed, but I will get to it as soon as I can.
If I can't get it open via the instructions in the video, what would you suggest I do/try next?
Old Sep 3, 2025 | 07:02 PM
Extinct's Avatar
You likely will need some curved tools (picks) to reach it. I generally find trying repairs gives me ideas for next steps.
Old Sep 4, 2025 | 07:57 AM
bjordan's Avatar
Thank you for all the help!
Old Sep 4, 2025 | 12:15 PM
zuke's Avatar
try this thread https://landroverforums.com/forum/di...ar-door-89952/
Old Sep 4, 2025 | 02:22 PM
bjordan's Avatar
Originally Posted by zuke
Thank you, but its the rear passenger door on my LR that wont open. Different actuators, unfortunately.
The womp
Dec 22, 2022 08:44 AM
CavSoldier3ACR
Dec 11, 2017 03:25 PM
reddiscovery2
Nov 24, 2012 08:51 PM
pgk
Mar 26, 2012 08:02 PM
yourbr.com
May 13, 2010 09:17 PM
