Lockers and Gear Ratios
Old Feb 14, 2019 | 10:24 AM
FlyingZebra34's Avatar
Default Lockers and Gear Ratios
Anyone here run anything besides the stock gears? Would like to upgrade to get more power.... Mpg's be dammed. 4:10 or 4:56 is the range I'm looking at. I'm running 32" tires and the poor thing is more gutless than usual. Also lockers would be nice.
Thanks all
Old Feb 14, 2019 | 10:43 AM
bcurtman's Avatar
Just curious...what is the stock ratio? Where there options?
Old Feb 14, 2019 | 11:34 AM
bcurtman's Avatar
Found it. 3.538:1
In the jeep world we call that 3.54
Old Feb 14, 2019 | 01:31 PM
Big Jim Swade's Avatar
I think Disco Mike put 4:10's in his.
Old Feb 14, 2019 | 01:45 PM
Friday Night Disco's Avatar
Jeff Blake did some gearing changes, do a search on his threads
Old Feb 14, 2019 | 01:46 PM
Fastercat's Avatar
Another option which I’ve been considering is a lower high range ratio in the transfer case. It looks way cheaper than 2 gear sets and the setup labour. I’ve never been good at setting the backlash myself. Todco makes the transfer case gear set
Old Feb 14, 2019 | 06:05 PM
Nigelw's Avatar
Or if you can find a good used but obviously cheap enough Defender 1.410:1 transfercase?
Ashcroft Transmissions in the UK make reduction gears for the transfer case, might be cheaper than CA/US $$$???
Old Feb 14, 2019 | 07:44 PM
Alex_M's Avatar
The issue with transfer case gear changes is that the stock driveshafts are already kinda tapped if you're beating on it out on trails any. As for setting backlash.... You can buy complete 3rd members already assembled in a bunch of ratios from lucky 8.
Old Feb 17, 2019 | 10:45 AM
I'm thinking 4:10 with air lockers is the best route for what I'm doing. And I agree about the driveshafts already at there limit. I'd like to keep the t-case stock on this one. I finally got it to stop leaking after the last rebuild.
Old Feb 17, 2019 | 03:13 PM
Nigelw's Avatar
You getting pegged too?
dirtydiscoparty
Feb 14, 2016 06:36 PM
FantomRover
Feb 26, 2015 05:45 PM
Dane!
Mar 24, 2014 03:00 PM
FlyingZebra34
Jan 9, 2014 06:36 PM
elrocha69
Jul 14, 2011 02:50 PM
