Looking to buy
Old Feb 12, 2011 | 11:49 AM
triplb25's Avatar
7th Gear
Default Looking to buy
Hi, new to this forum and had a question.
I have the opportunity to purchase a 2003 Disco with 74,000 miles on it for a very good price. Problem is, it has a sporatic misfire to it... Code that comes up is "misfire cylinder 8". Has new plugs and wires, any thoughts? MAF? Thanks in advance for the help!
Old Feb 12, 2011 | 06:30 PM
Probably a bad crank sensor, ~$65 DIY.
Make sure you read the "what to look for" in the tech section.
Old Feb 12, 2011 | 06:57 PM
triplb25's Avatar
7th Gear
Thanks, and I was hoping signs would point to something like that! Will read the what to look for!
Old Feb 12, 2011 | 07:01 PM
preple's Avatar
Do not forget about the fact that the oil pumps are bad on the 03's. Thanks Spike
Old Feb 12, 2011 | 07:26 PM
devildog01's Avatar
Not the cps or it would not run.#8 is a good indication of slipped liner.Stay away unless you have the $ for a new motor.
Old Feb 12, 2011 | 07:34 PM
preple's Avatar
http://www.consumeraffairs.com/autom...and_rover.html
Old Feb 12, 2011 | 09:17 PM
unimoged's Avatar
Had the same code on a 2004 DII. Replaced the valley pan gasket (lower intake) and it fixed it. These engines start loosening the lower intake bolts due to heat cycling during short trips. When that happens, coolant is sucked into the rear cylinders intake runners causing a misfire.
ibet7777
Off Topic
Oct 26, 2007 08:21 AM
Raiderfan
Oct 10, 2007 07:36 AM
projekz
Sep 11, 2007 09:31 AM
bmwboy
Jun 17, 2007 09:27 PM
alex of minnesota
Nov 1, 2006 11:22 AM
