Looks like I need to put a ring on it - advice on engine
Old Jun 6, 2024 | 03:14 PM
Roont's Avatar
Default Looks like I need to put a ring on it - advice on engine
I bought it with a non fouler in the #4 cylinder and when I had it open for head gasket, there was a ton of baked on oil on the top of pistons and valves. I did the valve seals as well, hoping, but it's gotten worse. Leak down confirmed
Wanted to see what best option is. Is there even a source of crate engine? Or a good source for block? With all the talk of the sleeves wandering and scoring, not sure if it's worth it to just replace the problems in that cylinder?
2001 4.4L 110k miles
Old Jun 6, 2024 | 07:43 PM
Richard Gallant's Avatar
No crate engines, there are long and short blocks available from various sources Atlantic British for one
Old Jun 6, 2024 | 11:03 PM
Roont's Avatar
​​​​​​Yeah I found theirs and Turner and clutched my pearls haha.
L​​​​​ooks like I'm going to tear it down and see if I can just do rings or piston. But mainly dig in and see what's specifically damaged.
It sucks, it was my only vehicle with AC and here comes summer .time to convert work truck to 134a I guess
Old Jun 7, 2024 | 06:34 PM
Extinct's Avatar
I would source an early 4.0 engine from will Tillery or one of the other Breakers and then rebuild it if I was you. If yours is a 4.6 you can put your crank rods and pistons in it and it will be a 4.6 but with the superior 4.0 block.
jsbutter
Apr 15, 2021 06:14 PM
twin6
Feb 23, 2017 09:02 AM
srockrae
Jan 18, 2013 10:54 PM
Erik
Engine & Internal
16
Mar 25, 2008 07:05 AM
Erik
Jul 3, 2007 04:44 PM
