Lower Engine Plastic Cover
Old Sep 15, 2017 | 12:16 PM
  #21
Fast951's Avatar
Originally Posted by number9
I was able to slip mine out the front by simply removing the steering stabilizer. It stays removed and it the areas it supposedly keeps clean get dirty there's better access for cleaning.
The underbelly panel prevents the early warning system(small leaks/seeps) from reaching the ground and being easily noticed while down below doing routine mx. It would be a PIA to remove for each inspection IMO and other repairs.
Likely originally installed to increase mpg by the previously mentioned 0.10 mpg and to reduce the number of reported leaks during the warranty period. To each his own.
Yes, removing the right side of the steering stabilizer allows the cover to easily slide into place from the front once the body is lifted.
I would say the few degrees reduction in running temps definitely trumps the increase in fuel economy.
Old Sep 15, 2017 | 01:34 PM
  #22
KingKoopa's Avatar
Just keeping the engine bay cleaner would make it well worth it for me. Filthy engine bays are awful on a vehicle that gets under-hood work at least once a month.
Old Sep 15, 2017 | 02:11 PM
  #23
Sixpack577's Avatar
Supposedly it runs cooler with it on, and slightly improves mpg.
As well as protecting the engine.
Old Sep 15, 2017 | 02:13 PM
  #24
Sixpack577's Avatar
If you still have to jack it up to get the cover out from the front by unbolting the stabilizer; then why not just unbolt nothing, and slide it out the back??
Old Sep 15, 2017 | 03:04 PM
  #25
number9's Avatar
FYI, in my case with all wheels on the ground was able to just remove the steering stab cylinder and remove panel without needing to lift the body.
schwaggy
Apr 13, 2025 07:02 PM
lrjon
Jul 20, 2019 05:18 AM
Ron Gomes
May 11, 2013 05:49 PM
bumpdaddy
Apr 15, 2013 12:01 AM
minsane
Feb 16, 2011 03:11 PM
