Lower Intake Manifold Question?
Old Aug 25, 2012 | 04:47 PM
C3racer2000's Avatar
5th Gear
Question Lower Intake Manifold Question?
Hi. New to Forums and new to Land Rovers. I am doing my first head gasket job on a 2000 LR Disco II. It's going well, I'm in the reassembly phase. I am installing the lower intake manifiold and there is no room between the bolts and the fuel rail to get a torque wrench on there. Is there a special wrench you guys use? I tried a wobble extension and one of those universals to try and get on their it won't fit. When I took the intake off the only thing that fit in there was a box wrench, but it needs to be torqued to 38lbs. and I can't get the socket and Torque wrench on it. I have learned alot from this forum, you guys who have done this what wrench did you use? Thanks.
Old Aug 25, 2012 | 05:42 PM
909wheeler's Avatar
Use a crows-foot wrench on an extension.
Old Aug 25, 2012 | 06:22 PM
jafir's Avatar
Or remove the fuel rail. Your head gasket kit probably came with new injector o-rings, you might as well install them.
Old Aug 26, 2012 | 01:04 AM
jfall's Avatar
Or do it by feel.
I felt how tight a bolt I would access with the torque wrench.
Tried to tighten it a little more.
Felt how much force was required.
And apply that force to the hard to reach bolt.
Taking apart the fuel rail is nice - but adds risk
as the more things one takes apart - the more
probability of something breaking unintentionally.
The fuel rail is the most delicate part of the cylinder head replacement job.
I left mine ON.
dougn
Dec 7, 2014 08:51 PM
me 2
Mar 14, 2013 08:36 PM
jsyonker
Nov 12, 2012 09:15 PM
br0keit
May 10, 2012 04:13 PM
